Crwcompact said:![]()
I really like this set up!!!!!
I haven't popped a bead, but I don't want to. Maybe I should just get them. They look good and it's probably safer with them on.zerofield said:I ride in the desert a lot and get rocks in the bead all the time. So i'm getting them.
if you pop the bead a lot or run low psi i'ld look in to getting some
i'll soon be running beadlocks with a reinforced ring. it maybe overkill but i've had too many rocks in my bead and dents in the rimfergie80 said:I haven't popped a bead, but I don't want to. Maybe I should just get them. They look good and it's probably safer with them on.zerofield said:I ride in the desert a lot and get rocks in the bead all the time. So i'm getting them.
Depends on what your doing. Low air presure and high speed or any situation that pushes on the sidewalls will push them off sooner or later. Broke-in tires seem to be more prone to this. It can be dangerous when a wheel digs in to the ground. I endo'ed my crawler because I popped a bead droping of a ledge. I went with bead locks after that.fergie80 said:Are beadlocks necessary? I mostly dune ride in the winter and in the summer I go up to the cinders in Flagstaff alot, occasionaly I trail ride. What do you guys think?
Yeah, I think that is going to be one of my next purchases. Besides looking really good, there probably safer to have on, you can get into a hairy situation if you pop a bead.CaptAz said:Depends on what your doing. Low air presure and high speed or any situation that pushes on the sidewalls will push them off sooner or later. Broke-in tires seem to be more prone to this. It can be dangerous when a wheel digs in to the ground. I endo'ed my crawler because I popped a bead droping of a ledge. I went with bead locks after that.fergie80 said:Are beadlocks necessary? I mostly dune ride in the winter and in the summer I go up to the cinders in Flagstaff alot, occasionaly I trail ride. What do you guys think?
