I’ve been around equipment and vehicles all my life. I know about safe handling, proper grounding, CCA, etc. Unfortunately, I don’t know diddly about AGM batteries or Ah vs CCA. I was told I need to find a better battery for my 06 Rhino 660. I’ve tried to research what will fit and I’ve found a 350 CCA U1 sized battery at Autozone. Right now, my machine is a little sluggish to crank over at times. New starter and relay are already installed. My current battery is pictured below. Built in 12/2020. Charging 13.3V at idle.
Motor vehicle Automotive tire Tire Automotive exterior Vehicle
Sports equipment Gauge Measuring instrument Audio equipment Tool
Discussion Starter · #2 ·
I’ve been around equipment and vehicles all my life. I know about safe handling, proper grounding, CCA, etc. Unfortunately, I don’t know diddly about AGM batteries or Ah vs CCA. I was told I need to find a better battery for my 06 Rhino 660. I’ve tried to research what will fit and I’ve found a 350 CCA U1 sized battery at Autozone. Right now, my machine is a little sluggish to crank over at times. New starter and relay are already installed. My current battery is pictured below. Built in 12/2020. Charging 13.3V at idle. View attachment 65126 View attachment 65127
I think I’ve found the answer to my own question. I think the Odyssey PC925 from Amazon will do what I need to do.
Product Font Screenshot Technology Tire
