Hi guys ..I Need some advice what to do from keeping my battery from draining down when I use my lights.. Im running a 40" light bar and 2 Ridge D2 hid.. What's he best setup for this...?? Better battery,stator,extra battery ect..
Please Help.. Also I have a rotax motor.. Thanks:banana:
Try using a switch to cutout the headlights. I run the same setup you have with a single xtreme X2-30. I will also let the motor run with lights out for a few min when I stop.
with the rhino running and all your lights on put a meter on the battery and see what the volts are. rev it up to about 3-4k see what it is then.
then when you are idling you can switch off the headlights to save power.
Thanks Guyz. I was woundering if anybody using a dual battery set-up.. if that would work.:aargh4:
