1 - 19 of 19 Posts
Does anyone know where to purchase the clips that hold the rear axle in the diff. Mine is 06 660?
its an OEM part from dealer or from Babbits or Rocky Mt ATV in OEM parts, they are about $4 each. Look at your model under Rear Wheel 2 category.
I have looked at my FSM dozens of times. To me it looks like the whole double off set joint must bought. I do not see them offered individually. I believe one came with an Empi boot kit one time. I am looking to buy them by themselves. Real old buying parts that aren't right or buying a whole kit just for one part of it.
This is off partzilla.com i think u need M #17
Discussion Starter #5
The one in the bag is #17 m. PN 5km-2536e10. The one I need is the other one in the picture. I thought #17 m also was the one needed and bought 4 of them.. The difference is clear. Thanks much for helping. Been driving nuts.
Which side r u needing drivers or pass
Never mind both sides on the 660 have same clip# that hold axle in diff
Dave can u take a pic of your axle with that big clip on it and the small one held up to the end, i dont even see how that big one would fit in the diff if the smaller one is the only one listed for all years 660’s both sides
It looks to me that u r looking for the clip that holds the cv in the cup, that is the only bigger clip i see in any parts diagrams
(C) not (A) and that makes since to me because u cant buy C as a seperate part
Discussion Starter #10
Will see what I can do for you. .might take couple days
Discussion Starter #11
My sincere apologies to you guys. The clips I have been looking for are the the big ones that hold the joint into the cup. Not the one in the diff. I feel so stooopid. Friggin senior moments. Happenin' more and more.
No problems man but now we know what u need let me see if i have a couple
Dave i looked thru all my stuff and dont have any of the big clips, try and send a PM to intro2rhino and see if he might have any
I think I may have one in my broken axle boneyard at my son's place. Let me know if you cant find one and I will look on Monday. I may have one here but it may be a Wolverine clip and if I am not mistaken they are different sizes, Can you measure the cup inner diameter and I will check my box tomorrow.
Discussion Starter #18
Thanks for looking man. Was wondering if I could make one out of music wire. The clips measure 0.06 thickness on the micrometer.
Let me be clear... I was thinking you need the flat circlip ring with the hole on each side of ring to squeeze with your circlip pliers. It is about 2 1/2" in diameter. I assumed you took it out and lost it. Even tho you could get some memory pressure with music wire, I would not do that for any permanent solution!
1 - 19 of 19 Posts
