1 - 11 of 11 Posts
I don't have any before I bent my front frame but i can take some after pics since I fixed it. I pushed the frame in about a half inch on one side and about a quarter inch and the other side. it's the lower rear arm mount. you want to guesset it up before you bend it.
Life serves the risk taker
How did you pull that out? I bent one of my lower rear arm mounts down and in a little.
I have the same problem, how did you fix it?
Vendor
I destroyed my frame once.. Used a frame straightener to fix it. Tore a arms out, bent in frame rails, bend the arm uprights (where they mount).
Then gusseted the hell out of it.
I bent the spindal and frame a little where the lower a arm mounts to frame. I replaced the spindal and adjusted tie rod to minimuize pull to pass side. Works okay but I'm ready to get the frame fixed. I was thinkin about filling in bent portion with scrap steel and welding it all up with gussets this time. I know it's not the best way to fix, but good enough for me. Where are ypou guys puting these gussets on a arms mounts? any pictures?
1 - 11 of 11 Posts
