1 - 13 of 13 Posts
Would you take 200. and i'll come get it?
Hey Dan,
I installed the alternator this weekend and it is not charging and alternator is sparking inside itself. Any ideas what is wrong with it?
Hey Dan,
Seriously? I can call UTV Inc tomorrow and see if they have any idea what's going on. I'm really sorry about that....I will make sure you are taken care of one way or the other.
Hey Dan,
Ok, thanks Dan. I tried it one more time and not charging at all, and after running it for about 2 min is starts sparking inside and is very hot. Let me know what you come up with.
Thanks Kevin
Sounds like a bad alternator. Get a voltmeter and check it for output.
But the fact that it's hot suggests a bad armature, or bad internal grounding.
I had to ground out the mounting plate on mine to the frame. Its probably not the problem but did you do that on yours.
1 - 13 of 13 Posts
