2008 rhino. Has electric steering installed. Problem is: sitting still or moving slow/fast the steering jerks to the left. Then usually the red light comes on and back to Armstrong. Turn off machine. Restart and light stays off. Steers great when it’s working. Could it be a sensor problem?
I don't recall seeing sensors in any of the kits I've looked at - it sorta sounds like a control module issue. Don't know if they have a "keep-alive-memory" circuit but if they do you might try disconnecting the battery for a few minutes then reconnect & road test? You could also touch base with any of the vendors of these kits to see if they have any useful input for ya. Good luck.
