on my 700 rhino, i sometimes experience a slight bog at slow engine speeds, when i first press on the throttle pedal. its not consistent but for example, if im riding around then come to a complete stop then attempt to accelerate, it some bogs, then accelerated fine. i search for a bit on the forum but only cam up with stuff for 660 rhinos. i was thinking it could be something to do with the fuel, like a dirty filter. so far i change the plug, cleaned the air filter, and cleaned out the throttle body. is the fuel filter in the fuel tank? what else could i take a look at?
It is in the fuel tank and you should inspect it...
I am not saying you need one but an a/f gauge would tell you if you are being starved for fuel or not...
And an MSD controller would allow you to adjust the fuel curve...although if it is bone stock it shouldn't be necessary...
You do have a stock exhaust right...and stock air intake...yes/no...
