1 - 13 of 13 Posts
Got the motor running everything great was warmed ready for a ride put in gear and it lunges forward lowered idle still does and if u hold the brake and crank in gear it will move forward also
possibly have the wet clutch one way bearing in backwards
there is an arrow on it to show the direction of rotation
I checked per the service manual and says if it turns clockwise it is right is that right?? Almost has to be the one way though I guess
On level ground with engine off, put it into gear, high or low, then push it forward. If the oneway bearing is in correct it will try to turn over engine. The rhino will free wheel if it is backwards.
Thanks guys it was the one way she is running now got another issue seems like the clutch won't ride the belt high enough to go over say 35 its a sleeve from james
My bet is on one of the weights is improperly installed.
Are these the 'overdrive' weights? If so, are you sure you installed them the right way?
Yes they are od weights I believe so anyway for u to explain so I can check
Discussion Starter · #11 ·
Yes James got me taken care of thanks again man
Discussion Starter · #13 ·
Well it is finally complete and run strong been on vaca for 8 days got back today put in the gorilla rear axles and front driveshaft
Changed the oil for the second time and adjusted the valves and I'm love in it runs great good power
Big thanks to all the vedors who had apart in it
1 - 13 of 13 Posts
