1 - 8 of 8 Posts
Need help my 2007 rhino keeps over heating and the fan cuts on but still don't cut the light off. I have ordered a new header pipe because mine is cracked in half and I hope that is not why the thing is over heating?
Any suggetions.
Clean the radiator. Mostlikely culprit.
Make sure to bleed the cooling system real good to O yeah welcome to the 660 overheating club
get a radiator shroud, I just about 50 miles in hot temperatures with lots of hills and strain on the motor. never got over 180 degrees
Take a trouble light and shine it through the rad. Is it clear and can you see light through the fins? Clogged fins a likely culprit.
Otherwise here is the run down from the trouble shooting manual.
Ignition system
• Improper spark plug gap
• Improper spark plug heat range
• Faulty C.D.I. unit
Fuel system
• Improper carburetor main jet (improper setting)
• Improper fuel level
• Clogged air filter element
Compression system
• Heavy carbon deposit
Engine oil
• Improper oil level
• Improper oil viscosity
• Inferior oil quality
Brake
• Brake drag
Cooling system
• Low coolant level
• Clogged or damaged radiator
• Damaged or faulty water pump
• Faulty fan motor
• Faulty thermo switch
Oil cooling system
• Clogged or damaged oil cooler
lots of possible causes most most often simply a dirty rad. You have to be able to see light through the fins.
Let us know how you make out.
1 - 8 of 8 Posts
