Here is the deal, every once in awhile, my rhino quits running.
Electrical is good, spark plug is good, give a good strong spark.
Gas tank, filters, carb cleaned up, all of the tubing has been replaced.
When it happens, it seems I'm not getting any fuel, it back fires a lot and then stops. If I get lucky, I'd wait 2 -3 min, it would start again when pulling the choke (not everytime)
If you leave the gas cap open, it doesn't matter.
I installed a gas tank that feeds by gravity from the top of the rhino, and it works.
I've replaced the fuel pump 4 times already.
pump 1 (stock original) worked 6 month
pump 2 worked 2 years
pump 3 worked 1 month
pump 4 1-2 months
Are the fuel pump junk or could it be something else I'm missing causing the fuel pump to fail???
Is there a better aftermarket? or should I install an electrical one?
Any help appreciated
thanks
Will
pump 4 1-2 months
thanks
Will
