Just got a rhino 660 that has been sitting awhile, it was running good i was riding around the yard and i came to a stop normally and then all the sudden it dies when i hit the gas, in all gears even neutral. Idles great but wont go.
Im gonna hook a gravity fed tank on to test if the feul pump is going out,
Clean the carb,
Compression test, then if thats not it
New coil, ive just put in a new plug
And im thinking of getting one of thes upgraded cdi boxes off amazon to hopefully eliminate the possibility of it being a rev/reverse senser issue.
Any ideas on other things to check would be appreciated.
so i checked the fuel system today. the pickup in tank was ate up and clogged, the stock fuel filter was clogged, and the main jet was gunked up. i got new line, electric pump i plan to set up as a pull through stock vacuum pump set up for priming/start. and went ahead and ordered a new carb. also found the yellow and black went to the carb heater, is that important or only for really cold areas?
