Is anyone using a 5 point harness? I have 4 point harnesses now.
I have been thinking of running 5 point harness only to pull the lap belt down a little. I don't really like the fact that my lap belt rides up when I sinch down my shoulder belts.
I have not looked yet but where would you mount the crotch belt?
· Life serves the risk taker
I run a 5 point and there is a very simple spot to install it. You think it will be too far to the inside but it is not. When your sitting in the driver seat look under your right leg below the seat and pull the vertical plastic away. There is big friggin bolt right there that holds the framing for the seat bracket and the front bracket together. It works perfect. All you do is remove the bolt and push it though the 5 point. I need to get a washer to space it away from the seat frame so I can adjust better. Oh also I think I notched the seat base plastics over there so the strap had relief and didn't bind.
