1 - 9 of 9 Posts
dose anyone run 29.5 outlaws on there bike. I would like to but dont know if i would have the power.Right now i run 28 zillas and have some mod muzzy,msd,cam,mudbuster clutch kit,sheave.do you think i could run them or just be way under powered and brake abunch of stuff.Thanks
The 28 zilla weighs about 26-27lbs depending on which size of 28 you get. The 29.5 outlaws weight is about 38lbs. This is from what i found. That will be an extra 40ish pounds so if you are already breaking stuff I would say plan on more. If you are not breaking anything sounds like you might start to me. Sounds like the outlaws will be tough on parts unless you have a really conservative right foot. Just IMO though I am going to be moving up to a set of 28 Zilla's.
I'm running 30-10-14 Gorilla Silverbacks and no problems as long u don't get crazy with the throttle cause they dig like crazy and if u hit something hard they will snap an axle
I think you will be fine with a 2 inch lift and some minor trimming. As for the power, yes just keep it in low if ur doing any mudding or any hill climbs and you will be fine. Post up some pics when u get that thing set up.
breakin an axle is part of the game **** happens if your worried about 40lbs just clean the mud from underneath and the beer bottles out of the back i wish i would have went to 30s
I have no lift just a little trimming on the blk plastic in frt of the rear tires and progressive hd shocks in the rear adjusted about half way
Sent from my PC36100 using Tapatalk
1 - 9 of 9 Posts
