1 - 14 of 14 Posts
27’ Baja w/new 509ci
1991 Baja 270 – 27 foot
Green/Yellow/White
The reason I’m selling this boat is that I’ve upgraded and purchased another larger boat. I’ve spent thousands of dollars in reconditioning almost everything on the Baja. A great poker run and/or overnight boat. The entire upholstery and carpets inside and out are clean w/no rips or tears. There is a double bed in bow and two facing seats located in the cabin that sleeps two very easy. The drop down bolster seats are clean and solid. The boat has a killer 134db sound system. Consider all items new unless stated other wise.
Motor:
Mercruiser – 49 hours on new motor
Everything on the motor is new and the build was completed by Kotzur Racing
New 502 gen VI block bored .030 to 509ci rated 475hp @ 5800 rpms.
Block & entire assembly was squared, decked, balanced, ported and polished
JRE Pistons 10:1 compression ratio (93 octane pump gas)
Competition Cam & Lifters (11-236-4)
Edelbrock 1410-750cfm marine carburetor w/complete jetting kit
Flame thrower coil 50k volt
New Masco marine alternator & Thunderbolt ignition assembly
Holley fuel pump system w/fuel & water separator
8.5mm plug wires
New low gear drive starter
Corsa Quick & Quiet stainless steel thru-hull exhaust
Again, all items are new on the motor, the only item re-installed was the intake manifold and heads but they too were port matched and polished.
Mercruiser Bravo 1 Outdrive with drive shower and two stainless steel props 23 & 24 pitch.
The stringers were checked and solid, new white bilge paint applied.
Electronics:
Pioneer AM/FM/CD 45 watts with detachable face plate
Amps: Rockford Fosgate 2-channel, Alpine 4-channel, Profile 4-channel
(12) Speaker System - 1200 watts total -Wired with 2 & 4 gauge power wire routed thru 30 amp fuse blocks
Speakers: (2) 12” Rockford Fostgate subwoofers
(8) 6.5” Kicker components mids/tweeters
(2) 6x9 Alpine 2-way
Batteries: (4) 12volt type 27 batteries with GIL Marine boxes and Perko power selector
Battery Chargers: (2) battery charging systems
Navigation & Instruments:
Livorsi Marine: all new yellow dash, gauges, Euro rocker-switches w/new labels wires, and connections.
Gauges: ProComp marine: Tachometer w/hour, MPH, fuel, oil, egt, O2, volts, temp
Lowrance Depth gauge 0-500ft
(20) LEDs throughout the cockpit which looks really cool at night.
Large Compass
VHF Radio w/36” antenna mounted on stainless collapsible mount
New white steering wheel
Trailer:
Eagle 1992 tandem axle trailer - Completely refinished
The trailer was disassembled and completely rebuilt.
Entire trailer sanded, 3 coats of white primer and 3 coats of white PPG paint.
(4) new 2x6 treated bunks covered w/black marine carpet.
(4) new axle races, bearings and seals
LED trailer running and brake lights
All new 10” hydraulic surge brake system – shoes, lines, and wheel cyls
American Racing aluminum wheels with Carlisle tires - 50% tread life
(1) new spare tire & wheel
Other:
Baja factory trim tab system
(4) life jackets
(4) bumper buoys
(4) dock lines
(2) stern lights
(1) danforth anchor w/5 feet of chain & 100 feet of anchor rope
(1) drop down stainless steel swim ladder
(2) blower vent motors
(1) bilge pump w/ float switch
(1) halon fire system
(1) fire extinguisher
(2) hatch actuators
(1) full cockpit snap-on matching cover
Maintenance: Complete tune up -new plugs, cap, rotor, all oil and outdrive alignment and fluids changed. Full detail twice a year: high-speed buffed and two coats of wax spring & fall. This Baja consistently gets compliment on how clean it is. The fiberglass is so slick you’d think it was brand new. The vinyl interior and colors are original Baja patterns and also in very good condition w/no tears, rips or stains. When not on the water, the boat has been stored inside and fully covered bow to stern. The boat is used and does have a few scratches along the side but no fiberglass structure issues. Dry weight is 4,350 lbs. I boat the lakes in Central Texas (fresh water only, no smokers or shoes on board) so I can demo for a serious buyer.
Boat Needs or Issues:
(1) hatch switch intermittently working
(1) small crack in the windshield 2”
(1) new owner as I can’t afford two boats
The boat has truly been babied with 99% of the cruise time @ 3-4k RPMs. The boat and trailer registration are current. I’ve tried to describe the Baja to the best of my ability and list everything honestly. Any questions feel free to contact me. The details of this vessel are in good faith but cannot guarantee or warrant the accuracy of this information nor warrant the condition of the vessel. A buyer should instruct his agents, or his surveyors, to investigate such details as the buyer desires validated. This vessel is offered subject to prior sale, price change, or withdrawal without notice. I can possibly assist with delivery only after full payment has been received and cleared any or all banks.
$21,500.00 USD – Make me an offer, I just might take it!
Contact Information: 210-344-6955
Discussion Starter #7
I really need to sell it bc I have a larger boat and need funds to finish it. Depending, I may consider a rhino 4 seater long travel +10k. Not the best pics but attached are more. Thanks for looking.
Discussion Starter #11
Thanks....it's still avail for sale. Summer will be here before you know it! Open to ReAsOnAbLe offers and can assist w/delivery.
1 - 14 of 14 Posts
