I weighed 4 of my 8 and they averaged 26.2 lbs each .....LanceThey look good...how much do they weight?
Yes...I have them on all 4 corners and they offer too much traction ....I probably will go back to a similar combination that I use to runDo u use them on ur rhino? How did they do?
Have you used them just for the rear? how did they do?Yes...I have them on all 4 corners and they offer too much traction ....I probably will go back to a similar combination that I use to runDo u use them on ur rhino? How did they do?
...sent with TapaTalk...please excuse brevity & no smileys
they weighed 25.5 lbs.I weighed 4 of my 8 and they averaged 26.2 lbs each .....LanceThey look good...how much do they weight?
No, haven't used them in just the rear....mounted all 4 corners at once and rolled like that the whole time.....Have you used them just for the rear? how did they do?Yes...I have them on all 4 corners and they offer too much traction ....I probably will go back to a similar combination that I use to runDo u use them on ur rhino? How did they do?
These are the "SUPER LIGHT" version that makes the rhino go faster!! hahaha :headbang::headbang:they weighed 25.5 lbs.I weighed 4 of my 8 and they averaged 26.2 lbs each .....Lance
You got the cheapies then...mine have an extra .7 lbs on them, so HaHa!!......LOL....j/k.....Lance
Well this is a cheap way to try it out! :fing02: Sure beats the price of sand blasters that some ppl swear by... LMK :fing02:Man I want to try asomeethin like this on the back of my rotax to see how they would do
How are youable to get that belt changed so quick? Is your fuel tank not in the way of the spreader bolt? NOt running a cvt cover? Would love to know your secrets.There are quite a few built rhinos up here running the STU 16 paddles in back and front, with the fronts having about a 60-40 cut on them ...they work great for our dunes if one has enough power
I'm running these 16 paddles all four corners and it is too much traction for mine ...the CVT belt is my weak point and lets me know how pissed off it is ...had to change another belt out yesterday in the dunes .....nice thing is it takes me 13 minutes now instead of 3.5 hours like before ......Lance
