I just replaced the starter and starting solenoid thing up by the battery,,,,I charged the battery as well,,,,was having a no start problem. Now I have a start/run problem,,,,,it starts up runs for a couple of seconds then dies. It has good gas,,,I use it almost daily. The new selonoid has two green fuses,,,,the old had two red 10amp fuses,,,,,could this be it??? I dont want to start tearing into it to check the fuel pump etc if it is a quick and easy fix,,,,,it has been a great 4x4 for running around on my property,,,,cant believe that there is now a major problem,,,,,need your help
