1 - 20 of 34 Posts
here you go
2012 Yamaha Rhino 700 FI Auto. 4x4 Sport Edition Home, information
MSRP* $13,399 (Metalic Sandstone) Available from July, 2011
ENGINE
Type 686cc liquid-cooled w/fan, 4-stroke; SOHC, 4 valves
Bore x Stroke 102.0 x 84.0mm
Compression Ratio 9.2:1
Fuel Delivery Yamaha Fuel Injection (YFI) , 41mm
Ignition 32 Bit ECU
Starting System Electric
Transmission Yamaha Ultramatic® V-belt with all-wheel engine braking/H, L, N, R
Drive Train Yamaha On-Command® pushbutton;3-way locking differential; 2WD,4WD, locked 4WD; shaft drive
CHASSIS
Suspension / Front Independent double wishbone; 5-way preload adjustment, 7.3-in travel
Suspension / Rear Independent double wishbone; 5-way preload adjustment, 7.3-in travel
Brakes / Front Dual hydraulic disc, twin piston
Brakes / Rear Dual hydraulic disc
Tires / Front AT25x8-12 NHS
Tires / Rear AT25x10-12 NHS
DIMENSIONS
L x W x H 113.6 x 56.6 x 73 in
Wheelbase 75.2 in
Turning Radius 153.5 in
Ground Clearance 12.1 in
Fuel Capacity 7.9 gal
Wet Weight 1199 lb
Bed Capacity 400 lb
Towing Capacity 1212 lb
OTHER
Instrumentation Digital LCD Multi-function display; speedo, odo, dual trip, hour, clock, fuel, and gear position
Lighting Dual 30W Krypton multi-reflector headlights & dual 21/5W brakelight
Warranty 6 Month (Limited Factory Warranty)
__________________
Read more: 2012 rhino - SXS******** - #1 SXS/UTV Informational Forum
Ha ha, my local dealer cut me a sweetheart deal to move this unit for the anticipated 2012's and it is the same!!! :banana:
Can anyone say 2014 for a real change?
Administrator
Better hurry to get one ......before all the 7.3" short travels are gone! ...Lance
...sent with TapaTalk...please excuse brevity & no smileys
Discussion Starter #5
2012 Rhino 700 FI Auto. 4x4 Sport Edition2011 Rhino 700 FI Auto. 4x4 Sport Edition
Remove -Choose Comparison Model- 2012 Rhino 700 FI Auto. 4x4 2011 Rhino 700 FI Auto. 4x4 2009 Rhino 450 Auto. 4x4 2009 Rhino 700 FI Auto. 4x4 2009 Rhino 700 FI Auto. 4x4 Ducks Unlimited Edition 2009 Rhino 700 FI Auto. 4x4 Special Edition 2009 Rhino 700 FI Auto. 4x4 Sport Edition 2008 Rhino 450 Auto. 4x4 2008 Rhino 450 Auto. 4x4 Special Edition 2008 Rhino 700 FI Auto. 4x4 2008 Rhino 700 FI Auto. 4x4 Ducks Unlimited Edition 2008 Rhino 700 FI Auto. 4x4 SE Midnight Armor 2008 Rhino 700 FI Auto. 4x4 SE Steel Blue 2008 Rhino 700 FI Auto. 4x4 Sport Edition 2007 Rhino 450 Auto. 4x4 2007 Rhino 450 Auto. 4x4 Special Edition 2007 Rhino 660 Auto. 4x4 2007 Rhino 660 Auto. 4x4 Ducks Unlimited Edition 2007 Rhino 660 Auto. 4x4 Exploring Edition 2007 Rhino 660 Auto. 4x4 Special Edition 2007 Rhino 660 Auto. 4x4 Sport Edition 2006 Pro Hauler 700 Auto. 2006 Rhino 450 Auto. 4x4 2006 Rhino 660 Auto. 4x4 2006 Rhino 660 Auto. 4x4 Exploring Edition 2006 Rhino 660 Auto. 4x4 Special Edition 2005 Pro Hauler 1000 Auto. 2005 Pro Hauler 700 Auto. 2005 Rhino 660 Auto. 4x4 2004 Pro Hauler 1000 Auto. 2004 Pro Hauler 700 Auto. 2004 Rhino 660 Auto. 4x4MSRP*$13,399 (Metalic Sandstone) Available from July, 2011
$13,399 (White Armor) Available from July 2010
ENGINE Bore x Stroke102.0 x 84.0mm102.0 x 84.0mm Compression Ratio9.2:19.2:1 Drive TrainYamaha On-Command® pushbutton;3-way locking differential; 2WD,4WD, locked 4WD; shaft driveYamaha On-Command® pushbutton;3-way locking differential; 2WD,4WD, locked 4WD; shaft drive Fuel DeliveryYamaha Fuel Injection (YFI) , 41mm Yamaha Fuel Injection (YFI) , 41mm Ignition32 Bit ECU 32 Bit ECU Starting SystemElectricElectric TransmissionYamaha Ultramatic® V-belt with all-wheel engine braking/H, L, N, RYamaha Ultramatic® V-belt with all-wheel engine braking/H, L, N, R Type686cc liquid-cooled w/fan, 4-stroke; SOHC, 4 valves686cc liquid-cooled w/fan, 4-stroke; SOHC, 4 valves
CHASSIS Brakes / FrontDual hydraulic disc, twin pistonDual hydraulic disc, twin piston Brakes / RearDual hydraulic discDual hydraulic disc Suspension / FrontIndependent double wishbone; 5-way preload adjustment, 7.3-in travelIndependent double wishbone; 5-way preload adjustment, 7.3-in travel Suspension / RearIndependent double wishbone; 5-way preload adjustment, 7.3-in travelIndependent double wishbone; 5-way preload adjustment, 7.3-in travel Tires / FrontAT25x8-12 NHSAT25x8-12 NHS Tires / RearAT25x10-12 NHSAT25x10-12 NHS
DIMENSIONS Bed Capacity400 lb400 lb Fuel Capacity7.9 gal7.9 gal Ground Clearance12.1 in12.1 in L x W x H113.6 x 56.6 x 73 in113.6 x 56.6 x 73 in Towing Capacity1212 lb1212 lb Turning Radius153.5 in153.5 in Wet Weight1199 lb1199 lb Wheelbase75.2 in75.2 in
OTHER InstrumentationDigital LCD Multi-function display; speedo, odo, dual trip, hour, clock, fuel, and gear positionDigital LCD Multi-function display; speedo, odo, dual trip, hour, clock, fuel, and gear position LightingDual 30W Krypton multi-reflector headlights & dual 21/5W brakelightDual 30W Krypton multi-reflector headlights & dual 21/5W brakelight Warranty6 Month (Limited Factory Warranty)6 Month (Limited Factory Warranty)
I still don't know how in the world they could MSRP this for $1300 more than a Teryx Sport.
what a joke. all the hype for nothing.
wow!!! 4 model years with no changes, and 8 years without any REAL changes. Im gettin' pissed.
But meanwhile all of my friends that own RZR's, including my folks, are always having issues with their rides. I finally decided to go with the Rhino after a year of watching these guys constantly fix something or have it in the shop. I'll take boxy and dependable any day of the week!
Before ya'll are too hard on Yamaha, just keep in mind who's been fighting the good fight for the UTV industry......just sayin'. :)
What I love most about the Rhino is how much personality you can put into one. As I see other SxS models they all look the same and that is just boring.
What I am still trying to figure out is who needs all of this "over performance" for what most people use a Rhino for (or SxS for that matter) in the first place. Is someone really needing to go 80 in a mud bog? :fingersx:
I think that's one of those idea's that sounds great before you do it, but upon entering that point of no return, you realize you have had too much beer and have been in the sun way too long, and after the deed is done you vow to never be this foolish again.... and then open another beer....
80 might be a slight overkill!! Desert, dunes, trails.. The rhino is underpowered for anything but flat land. If you ride in sand you will definitley see the power problems with the rhino. To get 80 out of a rhino, it would need a 1000cc and turbo charged! As far as beer and driving is concerned. You can get killed with too much beer on a 50cc dirt bike. If people are not smart enough to do the right thing when they drink too much then it is their own damn fault and should be welcomed to the 6' under club.
What does "need" have to do with anything? No one "needs" a rhino in the first place. You can see the trails better if you walk them. The rhino is underpowered, more power would help in thick mud, climbing hills, turning bigger tires, ect.
My friend's 9 month old Razor, with 900 miles on it, dealer maintained, just punched a hole in the case from the inside around the rear diff area. $650 just to pull the engine assembly to troubleshoot what caused it.
He just found out that the engine/transmission/diff assembly uses 5 different oil reservoirs, 4 different oils. Yikes. Wonder what happens if the tech accidentally mixes up the oils?
Front Gearcase Oil:
Polaris Demand Drive LT Premium Fluid
6.75 oz. (200 ml)
Transmission Oil: Main Gearcase
Polaris High Performance AGL
24 oz. (710 ml)
Transmission Oil: Transfer Case
14 oz. (414 ml)
Rear Gearcase Oil:
Polaris Premium ADF
18 oz. (532 ml)
Engine Oil:
2008: Premium 4-Cycle Synthetic OW-40
2009: Premium 4-Cycle Synthetic 2W-50
2010: Premium 4-Cycle Synthetic 2W-50
2011: PS-4 PLUS Synthetic Engine Oil
Oil Capacity w/wet engine 1.9 qts.
OEM Oil Filter - #2540086
1 - 20 of 34 Posts
