I have a 2010 Rhino 700 that has set for a year or so. Now when I try to start it, it will start right up and the die a few second later. Pressing the gas peddle doesn't help. I changed the spark plug and cleaned the air filter. I siphoned all the gas out of the fuel tank that I could and put fresh back in. After that I started it several times and it would do the same thing...die in a few seconds. I can hear the fuel injector kick in when I turn the key to start. Any suggestions would be appreciated.
Its the fuel pump you can hear not the injector. I would pull the pump out of the tank and look at the filter its on bottom of the pump. Its a 20min job but u should get a new gasket before u put pump back in
My also b a clogged injector, sitting for a year is a long time and ethenol gas can clog stuff up
Check to see if u have any codes
