I am just going to order a new filter tonight like you said it’s over 10 years old, any recommendations where to get it from. Thanks
replace it. You can get them at any auto parts store. Take the old one with you so that you can be sure that you get one with the right size intake outtake. Also if the fuel lines are original which they probably are, you should replace all of them including the pickup tube in the tank. While replacing the lines, switch the short one from the filter to the pump with the long one from the tank to the filter. This will allow you to have the filter sitting on top of the tank. This will make it much easier to replace the filter. Also, while doing this, you might want to take the tank out and clean it out. You will need to syphon out all the gas. You can't remove the tank with gas in it without spilling it everywhere. I washed it out with water, then poured a couple of ounces of Sea Foam in it, splash it around, and poured it out. I did the Sea Form part a couple of times. Every couple of tanks I run Sea Foam in the gas, 1 ounce per gallon of gas. You could run fuel injector cleaner instead.
If you don't replace your fuel lines and clean your tank, you might want to get a couple extra and keep one in your Rhino. i have a lidded box I keep in the bed with a tool kit, fuel filter, electric fuel pump and other stuff I think I might need. I replaced the crappy stock pump with an electric one off of amazon. It mounts where the stock one was. It was only $10, so I keep an extra. Actually I think your 700 has an electric fuel pump already.
