1 - 20 of 39 Posts
Hey guys I seem to be reading everywhere that the top speed for a rhino is around 40-42 mph without any work done. I bought my 2009 rhino 700 3rd hand and im only pushing 50kph or 30-31 m.p.h before the governor kicks in and I lose power. Is it possible that they had the computer tuned to run that way or am I missing something. Any help would be appreciated.
Super Lead Moderator
Your wet clutch may be slipping just enough to hit the rev limiter or you might check and service the the sheaves. I doubt they tuned it that way, pull the cover driver side (don't remove the primary sheave cage as it supports the shaft) and in nuetual rev the engine high and see if the belt goes to within 1/4" from top of primary sheave.
Your wet clutch may be slipping just enough to hit the rev limiter or you might check and service the the sheaves. I doubt they tuned it that way, pull the cover driver side (don't remove the primary sheave cage as it supports the shaft) and in nuetual rev the engine high and see if the belt goes to within 1/4" from top of primary sheave.[/QUOTE
My 2012 Rhino. bone stock, was lucky to get 35-36mph. I've done some stuff to increase that number but even at that I'm lucky to get much more than 53 mph. I'm okay with that though as I'm now approaching the ages of rock and I don't need to be hauling butt anymore. When you're out on the trail speed is not the major thing, pulling power is and if I had anymore "pulling power" I'd likely pull myself into a grave..:wink
Discussion Starter #4
That would make sense. I’ll have to wait to pull that off. I’m going over the entire unit and I have had it cleaned well yet so lots of dust and dirt to fall in. I’ll add it on my list to see if that’s the problem. I don’t need high top speed either but I would like my machine to be running the way it should to stop and future issues
COPY THAT!
Vendor
It would be rare to be a wet clutch issue and a 99% chance your primary clutch and rollers are just dirty and the rollers can't go to full travel so start there.
If you never been in the clutch before there are some tricks on reassembly that you do not want to miss so our our machined video for reassembly
https://www.hunterworks.com/rhino_clutch_removal
There is a link
Discussion Starter #7
Ok thanks for that. I will use that video plus my buddy is going to help me go through the whole clutch. I need a new one way bearing and I think I will be slugging it too. Want to do all the clutch work I can while it's open.
I just did Hunterworks "The Best" clutch kit and it took my top speed from 37mph to 50mph. Very happy with the results.
Sent from my Nokia 7.1 using Tapatalk
Discussion Starter #9
I think I will be doing that as well once I have the wiring and rest of unit up and running. Needs a good wash before I work on that kind of stuff.
Discussion Starter #11
does it look like i need to replace the clutch from these pictures? I also posted the pics on my weights that hunterworks recommended to look at and they are dirty as ever. My sheaves also look like they have a ridge built up that my belt couldnt go past. would that need to be replaced aswell?
Discussion Starter #13
Thanks for looking at them. I have a new clutch fixed sheave. Machines sheave from hunter coming as well. A new belt. And slugs for the clutch as well. Re doing the whole shebang.
Discussion Starter #14
New clutch came in!! Just waiting for the slugs and weights and machined sheave to come in! Can’t wait
Discussion Starter #15
Well a new clutch a new one way bearing, fixed sheave, hunterworks sheave and greaseless weights and a slug kit as well as a new belt.I’m up to 68 KPH slightly down hill. The take off is a little better but can’t remember from before. Been a few months since I’ve drove it. All in all happy with the upgrades and the original reason was definitely the weights were covered in grease and couldn’t get full travel.Added some new led headlights and fog lights while I waited for parts haha.
Discussion Starter #16
Does 68kph or 42 mph seem right when it comes to top speed after doing the machined sheave and new weights or am I still lagging and there is other maintenance things I can do to bring that up. I’m running brand new 27” Zillas as well
You need a aftermarket CDI I think the 27" tires are not helping.
Remembering now on my 700 I did NOT do step by step (which would have been smarter). Instead I bought, through Todd at Hunter Works, the Greaseless Sheave assy, Stage 1 cam and a Power Commander 5. My performance went from a top speed of 38 mph to 53 mph. Todd claims I should be closer to 60+ mph with this setup, so probably my tune is not spot on but I'm happy with the improvement. 40 mph is about max for the Tennessee trails I typically ride on. Low end performance is awesome.
Discussion Starter #19
I’m not sure I’m into doing to much else to it as far as a cdi and the cans. I’m happy with the speed I just wanted to make sure that I’m around where I should be with the mods I’m done. I also did the slug kit to add into that list. If I’m on par then all good. Just making sure there was more maintenance things that might be holding me up from it running normal.
Vendor
Not it should do 50, is it hitting the limiter or running out of power?
1 - 20 of 39 Posts
