1 - 13 of 13 Posts
2009 Yamaha Rhino 700
I just purchased a 2009 R7 and wanted to know if this model has any known problems or things to keep an eye on.
As of now it seems to run and drive fine, I just didn't know if it had any known problems, as about everything does.
Thanks
Welcome to the forum!
Rhino's are pretty solid acquisitions - especially the fuel injected ones. Don't know of any perpetual issues - just do maintenance when required and it should take good care of you. How many hours/miles are on it? Does it appear to be stock? Pictures would be helpful.
Have fun and good luck.
Far from stock, lots of mods.
Roll cage, King shocks, ITP wheels, spare tire, MSD ignition module, rear bench seat bolted into rear bed... k
Thanks
i got my 09 a year or so ago. The guy had added lights and a stereo. Aparently the stators on these are known to go out, especially if anythung electrical is added. I have to jump mine. It'll fire up and run great, just won't charge. I've read about adding an alternator or mounting a dual battery set up. That's the only issue I've had. So if you plan on adding any accessories, know it's coming. A couple hundred bucks for a new stator and it looks like a bit of a project to swap out.
Just got back from a few days in Matthews NC (not a Rhino trip 🙁). So mine is a 2012 model and I've yet to have (hope this doesn't bite me in the butt) any stator issues. See attached to get an idea of what they can handle:
As a long time owner of a Rhino, I replaced wheel bearings and rear knuckle bushings a few times. As stated check your voltage gauge if you have accessories,I replaced my stator 3 times. Keep your radiator hosed out from mud.
I’ve replaced all the wheel bearings at least once, 2 knuckles, 2 tie rod ends, the brake line, 2 wet clutches, 2 front skid plates, both rear brake calipers, and 2 axles. That said, I wouldn’t trade my Rhino for anything (maybe a 63 Vette….haha), it’s taken me everywhere I needed to go and some places I didn’t. It’s got a custom gauge panel with rocker switches for winch, light bar, fan override and done light, led headlights, a 20” light bar, mud deflectors, a custom made by me coolant bottle protector, rear underbed heat deflector, Rzr drivers seat, 3500 Super Winch, and 27” Mud Bug tires.
1 - 13 of 13 Posts
