Start cheap - check wiring from tank sensor to dash cluster. Look for possible rodent damage - they love the wire insulation. If wiring checks out then "likely" a bad tank sensor but I'm just guessing here.
Found the problem.seen where someone else had same deal.little fingers that contact the circuit bd. Weren't making good contact.Thanks for the help
