Rhino won't start. The engine turns over.
I have the choke pulled out completely.
It has 3/4 tank of gas.
I replaced the fuel filter 6 mo. ago.
I removed the fuel line between the fuel pump and the carb. It's pumping gas, but I'm not sure how much should be coming out.
Any trouble shooting ideas is much appreciated.
Start with the basics. Is the air filter clean, and is the air filter installed in the right direction? Is the carb getting fuel? Sounds like you've checked this. Is there spark at the plug? This will get you going in the right direction.
Got it figured out. It was a fouled spark plug. Thanks for the help.
I
I know this sounds crazy but pull seat on top of fuel tank there is a rubber grommet
Pull it out stick air hose in there and while cranking it over blow short burst of air
It will prime pump and start right up
