Well folks, the project continues on the 660. Just when you take two steps forward you take three steps back it seems.... Anyway, I was having issues with the OEM vaccum pump holding prime. It was start and run great but die during a long idle. Checking everything it was just losing prime. After some posts and research here I found where several had installed a K&N Electric Fuel Pump to correct the problem. The setup was exactly how my stock Rhino was so I went that route. Ordered the pump which is a 1.5-4PSI pump, and did the install.
It started and ran great but I caught a smell of fuel. I checked the output of the fuel pump and had a small leak. Contacted K&N who was very helpful and was advised to try yellow teflon tape on the threads. The tape did the trick! No leaks and all was perfect. Starts and runs like a champ. I hadn't had it out much since then but got it out on Friday and thought I smelled fuel again... rats! Checked the same spot as before and nothing. Couldn't find anything leaking so I thought maybe it was residual. Took it out yesterday and smelled fuel again and there it was leaking off the bottom of the skid plate.... but where from? I took everything apart and it was the fuel drain hose coming out the bottom of the carb and leaking on the skid plate. I checked the return line again and it was clear - no obstruction. I opened up the drain in case there was debris in the bowl then tightened it back up and it still leaks.
So.... it sure seems like it is getting too much fuel and the carb can't handle it. There is no adjustment on the pump and I do not have a fuel pressure regulator either. I don't believe there are any issues with the carb and it sure runs great - perfect in fact minus the leak. Anyone else ran into this before? Suggestions on a fix? I thought about trying to choke down the amount of fuel being allowed into the carb by restricting the size of the fuel line? I have an idea that might work but wanted to see what the experts did to fix before I try my jerry rigged experiment.
Thoughts/suggestions?
