1 - 20 of 56 Posts
been lookin at 2'' lifts..a nd doesnt look like theres much to them. so how much out or down does it relocate the shocks..cause i can build the brackets at work and weld them on..dont trust bolting them on
check out the rubberdowncustoms set up i have never had problems whith mine
Nothing against Rubberdown as he makes a great product that is forsure. I am running the cfm 2" lift and for the price I picked it up on ebay you cant beat it. I dont even think its worth your time making it for 50 ish bucks.
i dont remember ever seeing that cfm lift when i bought my rubberdown. it does look good to me. not the first time i spent alot more money than i needed to not the last either lol
so the bolt ones dont move or anything..they seem as if they would move..thats y i was goona weld some on
No the bold on lift will not move. The brackets have some material machined out so its a nice tight fit over your old mounts.
IMO this is the way to go with the rhino if your just looking for a little more clearance. Cheap and very effective.
MB
Would it be bad to only install the rear lift? I have a saggy back four seater. I have adjusted the preload on my progressive hd shocks, but I think the leverage that my wide offset wheels are putting on my shocks offsets the preload of the shocks and hd springs.
Sent from my iPad using Tapatalk
IMO just adding the back will make your rhino sit like an old camaro with something to prove. lol I would just put the front and back in its quick and easy to do and its only about 50$ for the kit off ebay.
I have the RDC front leveling kit and it is super strong and does a great job leveling up the bike! I modified it to keep the shock in stock alignment so the shock bushings would not bind at full compression of the suspension.
I would not recommend any lift on the rear unless you run limiting straps or notch the frame. With 3/4" of lift on the rear at full shock extension my right rear axle would hit the frame, not a real big deal but could cause premature failure of the axle.
Just installed cfm 2in lift. I went from 11 3/4 in to 14 1/2 inchs. It seems solid. The rhino is deff taller. And. If i had 28's or watever that one guy had and not 26's id be clearing a 5gal pail. Im 1inch away from clearing it. I give it 2 thumbs up.
I just got mine in today. Gonna put it on tomorrow any pointers but seems pretty straight forward. do you need to get an alignment after
no pix yet, but bustem504, for the front i had to grind some material off the lift bracket to clear the welds on the shock mount, and that was all pretty straight forward install, the rears i didnt even take the wheels off, if stuck google cfm 2in lift on images youl see pix of front and rear itll help.
Thanks moon took me about 30 mins it looks good now
Is the alignment off on your machine
i hvnt drivin it yet, just give it the old stanly alignment check.. using a measuring tape.
1 - 20 of 56 Posts
