Newbie here. Just picked up an '06 450 and looking at the 2" lift kits. Which one is the best bang for your buck? Also, will a 2" lift cause any kind of camber issues with stock wheels and tires?
Can't comment on which kit is the best. I got my 2" of lift when I installed Teryx shocks on my rhino. I can tell you it does affect the camber a bit. It's not a radical change, but in my case it is noticeable to the eye. Not enough of a change to motivate me to try and correct it.
The lift will also pull your tires/ wheels in a little bit. I haven't measured mine since the shock change, but it narrows the width just a bit.
