Ok, is this too good to be true?
Wood Racing has developed a bolt-on performance kit that does just that! All dyno tests were done on K&N Filters in house dyno with their technician at the controls. Dyno runs tested rear wheel horsepower with stock output at 19.3 horsepower, while the Wood Racing system increased the power output to 38.87 HP.
The performance kit consists of three major components, easy to install, replacing the intake, exhaust and ignition systems:
The FreeFlow carburetor kit consists of a specially modified and jetted Mikuni TM45 flat slide smooth bore carburetor, using the factory choke cable, a new throttle cable, plus the latest K&N XStream filter with built in velocity stack.
The new ignition increases the RPM from 7800 to 9000, with a comparable increase in performance.
The high performance exhaust is designed and built in-house, utilizing a true reverse cone megaphone that increases power throughout the entire rev range, excelling in midrange and top end horsepower, with a polished Cermichrome finish for good looks and durability. Supertrapp spark arrestor available on request with no loss of horsepower in testing.
Kit price $1,729.00
The Yamaha Rhino performance parts have been developed using decades of experience building the fastest four stroke singles in the world. Kits have been field tested under desert and dune conditions with excellent results.
Kit price $1,729.00
