1 - 2 of 2 Posts
No bubbles in radiator with lid off when running. Burped the bolt on drivers side of motor . Fan runs ..can drive it hour or two. But if you stop to take a break it will not start
2008 700EF
Have you checked what the engine temperature actually is? doesn't sound like the engine is overheating, sounds like maybe the coil is getting heat soaked? When you say it will not start after sitting, will it crank but it just won't fire? More information is needed.
1 - 2 of 2 Posts
