1 - 2 of 2 Posts
Bought a 09 700 Rhino that basically needed restored, rebuilt whole motor so finally got it running. I've taken care of any codes it had, Its hard starting when it runs it seems to run "good" has plenty of power but it will start miss firing at higher RPM's and if it try to go faster than 30 MPG. I do not have any after market ECM only stock so far.
Any ideas what to check?
Remember I bought this and the motor was junk so I have no history on how this ran prior to me owning it
Check your clutch sheave - most likely it is gummed up not allowing full travel of your drive belt - also may explain why it's cutting out. Your engine is reaching max RPM but your rev limiter is doing it's job by cutting out the ignition. Refer to Hunterworks Youtube videos for more info on your sheave.
1 - 2 of 2 Posts
