hey guys I have an 08 that will not go into gear shifts fine but wont go anywhere, I checked the linkage all good what next?
You may have smoked the wet clutch, if you need a new one stick with OEM not Ebay, you might order a slug kit from Hunterworks on here. Go to boats.com for the wet clutch and no you can't buy just the shoes.yeah I was pulling an ice shack in deep snow and got stuck really bad
Can you take a pic of the wet clutch. You stated "everything seems to be working fine" are you looking at the primary sheave or the wet clutch?I just remover the clutch housing and everything seems to be working fine
Well we know it's not the wet clutch.....:winksorry I forgot to say that the front drivers side cv shaft came out. the front main shaft turns but the rear does not
Unfortunately your middle drive shaft in the engine has broken right at gear inside, the front shaft runs off opposite end that is why it only works in 4 wdI have a 08 rhino special edition it will go in four wheel but not two wheel bi need help
