21 - 25 of 25 Posts
Does your rhino have a stock or aftermarket CDI ? Looks like it started to detonate-piston was overheating-rings stuck and piston started to seize …Why ?? The list is very long to correctly answer that not knowing the engine ,rhinos rigging, or history. Also that is really hard on the rod bearings….
Discussion Starter · #22 ·
Yes the previous owner put an aftermarket cdi in it. As far as anything else it seems stock minus the exhaust.
If your stock engine isn’t healthy , it’s over loaded ,fuel is old, etc a aftermarket cdi adds more timing and rev limits are higher-possibility is greater for engine failure at this point. Your cdi is fine up to 10-1 on a stock set up-if you rebuild the top end maybe consider a better piston 91 octane gas only -hopefully rotating assy isn’t damaged -lots of combs available -not a fan of the cheap kits…
Discussion Starter · #24 ·
The lower looks good and rod spins nice and smooth. I am going with a wiseco piston just not sure if I am going to replace or bore out the cylinder.
If your jug is OEM ,decks are true & can be bored to fit your piston of choice-perfect!!!!
21 - 25 of 25 Posts
