My 07 rhino still has the original tires on it and it is time for new ones. The fronts are 25x8x12 and rear is 25x10x12. I have heard I can go with up to a 27" tire with no problems is this true? Also do the front tires have to be narrower than the rear or can I put the same width on both ends?
Supporting Vendor
Many people have put 27 inch tires on their Rhino. Keep in mind, there will be some power loss with the bigger tire. If you are going to keep your stock wheels it would be best to stagger the width front to back.
Is there a tire you are looking to run? What type of terrain do you ride in?
Here is a link to our UTV tires where you can search by brand or size:
UTV Tires by Size or Brand | Discount Tire Direct
Please let us know if we can help.
I am looking for an aggressive set of mud tires I am also considering running wheel spacers to give it better stability.
