my dad has a 07 660 that was running fine when he got it used.... were he got it and were he lives is 1000 feet in elevation diff. he had it at his house and it ran fine for 10 miles or so. then he let it sit for like 2 weeks then went out and started it up and it fired like it should. put it in reverse pulled out of the shop put it in forward it started to backfire and spit and sputter. he shut it off and got it to start but had to hold the fuel to the floor. now it will not start....
IS THIS A JETTING ISSUE ... I AM IN NEVADA HE IS IN ID. HARD TO WORK ON IT WHEN I AM 7 HRS AWAY. I HAVE A 700 AND DONT KNOW MUCH ABOUT THE 660 PLEASE HELP US OUT
Its hard to say exactly what is the issue .......
I would 1'st check for spark if it's got spark then drain the carb and look for water bubbles. if so then theres the problem , if none then refill the carb and try it again.
