Can I order a replacement ballast for your kit?
It's making an odd sparking noise and the light is cutting in and out.
There is no brand name on it.
It's one of the kits that you had on sale back in the spring.
The small white sticker on the box said:
2006 Rhino HID Replacement kit.
MSRP $124.95 #2619
Written in black marker on the box top: 06 Rhino HID kit big ballast
Upon closer inspection, it wasn't the ballast after all. It was a bad plug connector right at the headlight that was arcing sparking inside itself. It's funny because it would always work when you first turn them on, then after a minute, they would flicker (sparking noise) and finally shut off. Ended up cutting out the connector plug and hard wiring it together with some shrink tube over top.
