When I start moving, the first foot or two are at a normal acceleration and then it slows down. It doesn't matter what the rpms are at it creeps. Does the same in 4x4. Any help would be greatly appreciated.
Vendor
So you are saying when you mash on the gas, the rpm goes up but you do not speed up?
If so, most likely culprit is the wet clutch.
Feel free to call me and I can help you figure that out and if you want to get parts here too, can help with that but that is not required.
Todd
I've pulled the cover off. The belt looks new. I can still see the writing on it. Now the arrows are pointing towards the rear, is that right? There was also a lot of water inside the cover. Is that ok? I tried calling you Todd. I'll try again tomorrow.
